Title pretty much says it all
Seen a few posts about the 3.8(75) intake being "modded" for the 3.5 (74) but can not for the life of me find an instructional write up.
Basically I wanna know
What requires modifying to make it fit 74? Do I need new throttle cable? Are the mating surfaces the same? Does the 3.5 tb bolt on no fuss or does it need "adjustments"? Do the runners port match the stock lower intake manifold? Is it the whole upper and lower parts? If not are there beneficial options available? And probably other potential problems or notes would be awesome
Also what about cams? Should I try find some 380 cams or get mine reground? Will the tbelt still fit? Should I be looking for another kind?
Are there any proven and tested exhaust systems that give proper results? Is aftermarket or a magna sports better?
Lastly ECU in KE do I need to reloom half the car or will a newer model retrofit in plugnplay style?
Ultimately I want a little more punch for the missus but still be streetable without spending 2.5k+ on engine conversions or boosting. Any thoughts and recommendations are appreciated.
Staffy
